Obd2 Anahtar Progralama ile Araç çalınırmı?
Olcay Sert
videoyu izledimde linke tıklamamıştım. sayfayı translate edince şu yazıyla karşılaştım
Spoiler
The device for a 10-90 OBD II programs across all car keys FORD EUROPE, USA / (2005-2016) without having to connect to the Internet. It is only necessary to have a suitable key / transponder for this car, turn on the ignition, then connect your device and a pozhdat 10-90 is the key / transponder will be programmed.
A device with a 30-40 OBD II programs across all car keys MAZDA (2005-2016) without having to connect to the Internet. It is only necessary to have a suitable key / transponder for this car, turn on the ignition, then connect the device and follow the instructions for programming keys / transponders.
Important!   As for cars FORD / MAZDA (2005 - 12.2012) should be used transponders Texas Crypto 4D - ID63 (40 bit) or the original key for a particular model, and for FORD / MAZDA cars from 2013 + need to use transponders Texas Crypto 4 D - ID63-6F (80 bit) or the original key for a particular model. In some car models after 2015 use new charms with Hi Tag transponder 3. In addition, if the car  with keyless (Keyless Go),  whereas for the models (2011-2014) is better than the original key to be programmed Go Keyless, since programming of the transponder just can not afford to have a car!
benim anladığım sacece uygun anahtar lazımmış programlamak için :/
10 dakika önce, Olcay Sert said:
@Özer aksu burda hersey daha net bence. Adamda calistigina sasirdi sanki really derken, icimi kapladi bi suphe obd baglantisini guvenli yapmak gerek ama nasil
O zaman askerdeki gibi dolap anahtarı ile kilitleyeceksin :)
