Fotoğraf Yarışması:
Mayıs ayı katılım
Nisan ayı oylama devam ediyor
  • Welcome!
Sign in to follow this
Mehmet Demir
Ford Etis Değişiyor
Recommended Posts
Gelen email..
Yeni sistemde 2 günlük, 1 aylık ve 1 yıllık üyelik satın alınabilecek, ford araçlarına hizmet vermek isteyen servisler için.
2 günlük üyelik alımı iyi birşey çok pahalı olmazsa..
Dear Independent Operator,
Ford Motor Company Limited will be in due course implementing a mandatory Global Online system called Global Ford Dealer and Repair System (Global FDRS) and existing FordEtis FDRS Online Applications will no longer be available.
However, in preparation of the Global FDRS switch on, Ford Motor Company Ltd is requesting that all independent operators download and install the Global FDRS software application onto their computer’s prior to the 29th September 2019 by following the instructions set out in the document available for download at https://www.etisload.ford.com/EtisGFDRS_SetupProcessGuide.pdf.
Global FDRS switch on date will be the subject of a subsequent email.
Charges
Charging of the Global FDRS system, you will be able to purchase a 48-hour, 1-month and an Annual License. The Global FDRS license will incorporate a Ford IDS License, access to FordEtis online Technical Literature i.e. mechanical repairs, Wiring diagrams etc. and Global FDRS Applications for unlimited Vehicle Identification Number’s (VIN’s) entered for the Global FDRS License purchased.
Notes:
There will be no additional charging for FordEtis Online technical Literature and FDRS applications.
EU5 Accreditation Security Access
Independent Operators that already have EU5 Security Accreditation Access will be unaffected by the switch over and will be able to use Global FDRS.
Independent Operators that wish to purchase EU5 Security Accreditation Access, to be able to use Global FDRS for key programming and certain module security applications within Global FDRS can do so by contacting the Ford IDS helpdesk at the following email addresses:
United Kingdom: idshelpdesk-uk@msxi-euro.com
Germany: idshelpdesk-deu@msxi-euro.com
Rest of Europe: idshelpdesk-ru@msxi-euro.com
Independent Operators without an Active Ford IDS License
Please review the process document available for download at https://www.etisload.ford.com/EtisGFDRS_SetupProcessGuide.pdf on how to set up, purchase licenses and use Global FDRS.
Independent Operators with an Active Ford IDS License
Existing Users that have purchased an Annual Ford IDS License Activation code, (via the FordEtis Online Application) from Ford of Europe will be able to use Global FDRS with their existing Ford IDS License until it expires. Once it expires, you will be able to purchase either a 48-hour, 1-month and annual Global FDRS License.
Independent operators that have purchased their Ford IDS License Activation Code via another supplier/company other than Ford of Europe will be prompted to purchase a 48-hour, 1-month or an Annual License to be able to use the Global FDRS Application.
Regards
Share this post
Link to post
Share on other sites
Ford etis artık çalışmıyor mu bir kaç oldu deniyorum araç bilgileri çıkıyor ama donanımı göremiyorum. İyi akşamlar.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Focus Club Türkiye
  • Create New...
Important Information
